Another Clunk In Rear End
First, I have an 06' Sierra 1500 4X4 SLE2. It has 33" tires on 20"X10.5" wheels. Not too big, but heavy and make a slug of a difference. I had the gears changed from 3:43's to 4:10's with a swap on the G80 for an auburn unit. The rear gears are OEM. It has dual magna flow exhaust, CAI, and a performance tuner (not sure it does anything though)
The problem lies here, gears changed. Drove it about 1000 miles, light driving and a trip to Vegas (15.2 mpg) and took it off road once in the hills on a well known hill to make sure all worked. I was just thinking about changing the fluid when I started to get a CLUNK in the rear end somwhere. It happens when it shifts from 1-2 occasionally and from 2-3 95% of the time. I got underneath it and grabbed the driveline and am able to move, rotate only, the driveline about +/-.125". I was not able to move it up and down, side-to-side. I took it back down to the place that did the swap. The took the drive line out and seems that the U-joints are fine. They then grabbed the propeller shaft and started to rotate it back and forth and it was making the similar noise I am hearing. They said that the play was normal and I went over to another truck they had there and it too did it. They said that I just never noticed it before but this is BS. I guess I am kind of peculiar and notice things that even a deaf person would hear. Any ideas on what I could look for? I am getting ready to take it to another shop, but would rather not. Sorry for the long post and thanks for reading!
