Lt265/75-16 On Stock Pyo's
buddy95z
For those that have gone up from the stock 245/75-16 Load range E on stock PYO's, how much of a difference in handling have you noticed going up to a 265/75-16 Load range E? Is there any noticeable sway in the tire or seem to push through the turns more? I'd like to step up the tire size a bit, but not at the cost of handling and general feel of the truck.
Thanks for any input. :thumbs:
Buddy
I have 265/75/16 Michelin LTX on my truck. They ride much smoother, due to a lot more sidewall. These tires are also ultra quiet at highway speeds. The truck handles way better, mostly due to the much larger contact patch. IMO its the best 1200 bucks I have ever spent.
If you want to go with an all-terrain tire...they also make one called the AT-2 it has some small side biters and a more aggressive thread pattern, but still very quiet.
Both tires are rated for 100K mile thread wear. A few guys I have talked to about them have had them for years on they're trucks. The usual I hear from people is 4 years...I have heard from one guy he had them for 6 years...and he had enough thread to make them last another year.
Another side on this....we use the LTX on all our ships trucks and passenger vans in the navy out here.
    Fishboat
    Fishboat
  • Who's Online   6 Members, 0 Anonymous, 515 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
