No Rke?
Hey everyone. Bought a 2007 Silverado W/T crew cab this weekend. All we were handed were just the keys, no remotes. I asked the dealer about them, and said that they weren't given any remotes from the previous owner. I thought pretty much all came with keyless entry anymore. I was looking at buying a couple of remotes, but don't want to waste the money if my truck isn't equipped for it. How can I tell if my truck has RKE?
VIN 2GCEC13C271508428 (if needed)
TIA,
Dave
TIA,
Dave
Sticker in the glove box has all the options - dealer or someone here should be able to tell you which code to look for.
TIA,
Dave
Look on the inside of the glove box for the sticker with all the RPO codes. I believe AU5 is the code for remote keyless entry.
  • 9 months later...
I have a 2009 Silverado with power door locks and no remote keyless entry. There isn't a code for RKE in glove box (AU5) but does AU3 is there. Can Remote entry be enabled?
From VINDECODE :http://www.compnine.com/vid.php
Starting...
Vehicle: CREW CAB 1/2 TON
Year: 2007
Build Date: 2006-10-18
Found 1,381,212 vehicles matching your year and model in our database.
RPO Description Matches Compare
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
1,297,395
UJ6 INDICATOR,LOW TIRE PRESS LOW TIRE PRESSURE IND(UJ6)
1,381,212
UM7 RADIO,AM/FM STEREO,ETR,INCLUDES CLOCK STEREO W/CLK(UM7)
41,029
UQ3 SPEAKER SYSTEM,PERFORMANCE ENHANCED AUDIO ENHANCED SPKR SYS(UQ3)
917,194
VB3 BUMPER,REAR STEP,INCLUDES IMPACT STRIP(CHROME) CHROME STEP BPR(VB3)
1,356,628
VG3 STRIP,FRONT BUMPER IMPACT FRT BPR IMP STR(VG3)
1,381,212
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
1,088,258
VXS Unk. 1,381,212
V73 VEHICLE STATEMENT - US/CANADA US/CANADA VEHICLE STATEMENT(V73)
1,340,415
X88 CONVERSION CHEVROLET CHEVROLET(X88)
917,827
YD3 AXLE FRONT (BASE EQUIP) FOR SCHEDULING GVW PLATE FRT AXLE(YD3)
1,381,212
YD5 SPRING,FRONT(BASE EQUIPMENT) FRT SPRING(YD5)
1,381,212
YD6 SPRING,REAR(BASE EQUIPMENT) RR SPRING(YD6)
1,381,212
ZK3 IDENTIFICATION PULL-A-HEAD DESIGN ID 2007 PULL-AHEAD DESIGN(ZK3)
1,381,212
ZPR TIRE SPARE P245/70R17-108S BW TL ST ALS TIRE(ZPR)
363,933
ZY1 COLOR COMBINATION SOLID SOLID PAINT COMBO(ZY1)
1,381,212
Z83 CHASSIS PACKAGE,SOLID SMOOTH RIDE CHAS PKG(Z83)
110,416
1SZ PACKAGE OPTION- (1SZ)
1,231,116
1WT PACKAGE WT OPTION 1 "WT" PKG(1WT)
61,626
25U EXTERIOR COLOR,PRIMARY (25U)
PRIMARY COLOR EXTERIOR, DARK MING BLUE (02) (25U)
103,430
6YT COMPONENT FRT LH COMPUTER SEL SUSP (6YT) SUSP(6YT)
95,202
7YT COMPONENT FRT RH COMPUTER SEL SUSP (7YT) SUSP(7YT)
95,202
88B TRIM COMBINATION CLOTH, DK TITANIUM(B) (88B)
156,613
88I INTERIOR TRIM DK TITANIUM (88I)
170,277
AE7 SEAT,FRT SPLIT,EASY ENTRY EASY ENTRY SPLIT F/SEAT(AE7)
170,277
AJ1 GLASS,DEEP TINT(REAR SIDE WINDOWS AND REAR DOOR WINDOW) DEEP TINTED GLS(AJ1)
1,330,543
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR INFL REST IND SENSOR(AL0)
1,381,212
AM1 CONTROL SEAT, MANUAL LUMBAR, DRIVER MAN LUMBAR DRIVER SEAT CONTROL(AM1)
968,982
AT8 RESTRAINT PROVISIONS CHILD, RR SEAT, RR FACING RR SEAT RR FACING CHILD RESTRAINT PROVISIONS(AT8)
1,381,121
AU3 LOCK,SIDE DOOR,ELECTRIC ELEC S/D LK(AU3)
1,380,865
A68 SEAT RR SPLIT, FOLDING FLDG SPLIT RR ST(A68)
1,381,212
BG9 COVERING,FLOOR(RUBBER) RUBBER FLR(BG9)
61,759
C5U GVW RATING(6800 LBS) 6800 LB GVWR(C5U)
561,587
C67 AIR CONDITIONER,FRONT,ELECTRONIC CONTROLS A/C FRT ELEC CONT(C67)
442,153
DE2 MIRROR,OUTSIDE,LH & RH,DIRECT CONTROL,FOLDING,PAINTED O/S MIR(DE2)
84,809
DK8 CONSOLE ROOF INTERIOR, DELUXE ROOF CONSOLE(DK8)
1,381,212
E63 BODY EQUIPMENT,FLEETSIDE PICKUP BOX FLEETSIDE PUBX(E63)
1,381,212
FE9 FEDERAL EMISSION CERTIFICATION FED EMIS(FE9)
1,164,108
GU5 AXLE,REAR,3.23 RATIO 3.23R(GU5)
226,110
JF3 BRAKE VAC POWER, 17" DISC/DRUM, W/ABS, 7, 000 LBS 7,000 LB VAC PWR BRK(JF3)
1,271,380
JJG FRT END SUBASSEMBLY INSTALLED (MODULAR OPTIMIZATION FRT END SUBASSEMBLY(JJG)
1,019,974
JL4 CONTROL ACTIVE BRAKE ACTIVE BRAKE CONTROL(JL4)
1,381,212
KG3 GENERATOR 145 AMP 145 AMP(KG3)
1,381,212
K34 CRUISE CONTROL,AUTOMATIC,ELECTRONIC CRCONT(K34)
1,345,923
LY2 ENGINE GAS, 8 CYL, 4.8L, SFI, IRON, CYLINDER DEACTIVATION GM 4.8C W/CYL DEACTVN(LY2)
341,004
M30 TRANSMISSION,AUTOMATIC 4 SPEED,4L60E,ELECTRONIC 4-SPD A/TRANS(M30)
1,271,380
NT8 EMISSION SYSTEM FEDERAL, TIER 2 A TIER 2 A FED EMIS(NT8)
1,164,108
NX7 WHEEL 17 X 7.5, STEEL STEEL WHL(NX7)
52,897
NZ4 WHEEL SPARE FULL SIZE, 17" STEEL FULL SIZE SPARE WHL(NZ4)
1,381,212
OSG PLANT CODE OSHAWA, ONT, TRUCK, GM OF CANADA OSHAWA,ONT TRUCK PLANT(OSG)
1,019,974
QPR TIRE ALL P245/70R17-108S BW TL ST ALS TIRE(QPR)
306,253
ROO Unk. 193,494
R6K Unk. 1,231,190
R6P Unk. 1,230,934
R9N Unk. 1,230,934
R9Z Unk. 1,381,173
SAF LOCK SPARE TIRE, HOIST SHAFT SPARE TIRE LOCK HOIST SHF(SAF)
1,264,457
SLM Unk. 1,222,920
SSB Unk. 1,381,212
T74 HEADLAMPS CONTROL AUTOMATIC, DELAY AUTO HLDP(T74)
1,373,221
