Maintenance
jrod332
I have an 05 1500. I believe the last time I checked I have about 95,000 miles. I am wondering what should be done for maintenance. I dont have a manual so I'm not sure on what is recommended. I just did a tranny filter fluid/filter change so I good there. Fuel filterI believe is non serviceable. I pulled one of my plugs the other day and it looked ok. Im not sure when there done last and I dont know what looks bad. The plugs and wires seem pretty easy to do on this truck which makes me happy. On my last truck you could only visually see 2 of them. Also where is the distributor and cap located? And what is the platic modual between the wire and the motor? Not familiar with this newer stuff.
My plug
My plug
No distributor cap. Those modules are the coils for each cylinder. You might want to change the diff. lube. Take a look at and maybe clean your MAF and the throttle body. Coolant? How long since it's been changed if ever? Belts and hoses?
You can download a PDF of your manual.
Go here and register. You don't need your VIN
    busse
    busse
  • Who's Online   5 Members, 0 Anonymous, 731 Guests (See full list)
