Nnbs Pcm Blackbear Tuned Clusters Grill Mirrors
I have some parts left over from my 2000 and 2008 1500 Silverado 5.3 and some spare parts from my 2003 duramax. All prices are OBO and they are all located in Maine.
Chrome Tahoe/Silverado grill slight crack on the driver’s side where it mounts but isn’t noticeable when on the truck that I know of can easily be glued for a permanent fix. $175 shipped
Magnaflow exhaust tip 4inch tip 45 slash cut stainless steel bought for my 2000 1500 never used brand new. $60 shipped
Rear Brake pads for Silverado’s with rear disk brakes. I bought them for my 2000 Silverado z71 Brand new never used. These were the midgrade to higher ones sold at the store I bought them. Sold the truck before I put the pads on. Brand new $35 shipped.
Mirrors for NNBS (2007-present trucks). 5000 miles on them. They are full power and heated mirrors. Work perfect not scratches like new plug and play. $250 shipped for both or $125 a piece.
35 inch bfgs a/t for 20 inch rims with about 5000 miles on them they look new no burnouts or anything. Prefer not to ship $1500.
20 inch 9.5 wide for chevy and dodge 8 lug bronze KMC monsters with lug nuts. They are like new 5000 miles on them. Prefer not to ship $1100.
Corvette servo for 4l60e transmission. Brand new never used. Was going to put it in my 2008 Silverado but never got around to it. I ordered it from Oregon transmission it is 100% complete with instructions. Great cheap shift kit $30 shipped
TCM for NNBS 2007 to present trucks. It is 100% working it was the original one it my 2008 Silverado but then I had the truck blackbear tuned. It is a great core or someone looking for a replacement TCM it was in a 2008 Silverado 5.3 automatic should work fine without reflash but no guarantees. $90 shipped
Stock ECM ECU PCM out of my 2008 Silverado 5.3. It is 100% working it was the original one it my 2008 Silverado but then I had the truck blackbear tuned. It is a great core or for someone looking for a new pcm. $250 shipped
BLACKBEAR TUNED PCM. It was in my 2008 Silverado. It is tuned for a 5.3 with 3.73. It has 100% TM removed, advanced timing for running premium or regular (truck can sense the difference). Raised line pressures. Much more it is a great upgrade and will work in your truck without being reprogrammed to my knowledge (worked in my buddies 5.3 NNBS). $450 shipped.
Gauge cluster for a NNBS truck. I was going to have my cluster modified and customized and I was going to use this as a core but never got around to it and sold the truck. It is 100% working condition 6000 miles or so on it. Works with steering wheel controls and the 4 button information center on the side. Also backup sensors. $300 shipped
ATS copilot for Duramax diesels with 5 speed automatic Allison 1000 transmissions. Updated version. Comes complete with all the wiring and regulator and control box. Works awesome increase clutch plate pressure and prevents slipping between shifts. It is a great way to beef up your Allison without spending $5000 dollars. $850 shipped.
2 Procomp MX2.0 shocks for 01-07 2500hd trucks with a 4-6 inch lift. They are the MX2.0 shocks they are front shocks. Brand new never used. They are high quality shocks. $250 shipped.
I can be reached at [email protected] much faster than on here.
Some say it needs to be programmed to the VIN but I have never had to. I have put my blackbear PCM in my buddies 5.3 and that PCM is VIN programmed and it still worked fine with no engine codes it was in his truck for about 500 miles. Don't quote me on it but I am almost positive that it will work without being reprogrammed in a NNBS 5.3. Also what are you using this for? If its for a custom tune core it will work just fine cause with the custom tune it gets reprogrammed.
Yeah I was going to use it for the core for my BB tune when I get it, that way I can switch them out for service work if need be.
Chrome Tahoe/Silverado grill slight crack on the driver’s side where it mounts but isn’t noticeable when on the truck that I know of can easily be glued for a permanent fix. $75 shipped
Magnaflow exhaust tip 4inch tip 45 slash cut stainless steel bought for my 2000 1500 never used brand new. $40 shipped
Rear Brake pads for Silverado’s with rear disk brakes. I bought them for my 2000 Silverado z71 Brand new never used. These were the midgrade to higher ones sold at the store I bought them. Sold the truck before I put the pads on. Brand new $25 shipped.
Mirrors for NNBS (2007-present trucks). 5000 miles on them. They are full power and heated mirrors. Work perfect not scratches like new plug and play. or $100 a piece.
35 inch bfgs a/t for 20 inch rims with about 5000 miles on them they look new no burnouts or anything. Prefer not to ship $1100.
20 inch 9.5 wide for chevy and dodge 8 lug bronze KMC monsters with lug nuts. They are like new 5000 miles on them. Prefer not to ship $900.
TCM for NNBS 2007 to present trucks. It is 100% working it was the original one it my 2008 Silverado but then I had the truck blackbear tuned. It is a great core or someone looking for a replacement TCM it was in a 2008 Silverado 5.3 automatic should work fine without reflash but no guarantees. $60 shipped
Stock ECM ECU PCM out of my 2008 Silverado 5.3. It is 100% working it was the original one it my 2008 Silverado but then I had the truck blackbear tuned. It is a great core or for someone looking for a new pcm. $160 shipped
BLACKBEAR TUNED PCM. It was in my 2008 Silverado. It is tuned for a 5.3 with 3.73. It has 100% TM removed, advanced timing for running premium or regular (truck can sense the difference). Raised line pressures. Much more it is a great upgrade and will work in your truck without being reprogrammed to my knowledge (worked in my buddies 5.3 NNBS). $350 shipped.
Gauge cluster for a NNBS truck. I was going to have my cluster modified and customized and I was going to use this as a core but never got around to it and sold the truck. It is 100% working condition 6000 miles or so on it. Works with steering wheel controls and the 4 button information center on the side. Also backup sensors. $200 shipped
ATS copilot for Duramax diesels with 5 speed automatic Allison 1000 transmissions. Updated version. Comes complete with all the wiring and regulator and control box. Works awesome increase clutch plate pressure and prevents slipping between shifts. It is a great way to beef up your Allison without spending $5000 dollars. $700 shipped.
2 Procomp MX2.0 shocks for 01-07 2500hd trucks with a 4-6 inch lift. They are the MX2.0 shocks they are front shocks. Brand new never used. They are high quality shocks. $150 shipped.
  • 4 weeks later...
Magnaflow exhaust tip 4inch tip 45 slash cut stainless steel bought for my 2000 1500 never used brand new. $35 shipped
Rear Brake pads for Silverado’s with rear disk brakes. I bought them for my 2000 Silverado z71 Brand new never used. These were the midgrade to higher ones sold at the store I bought them. Sold the truck before I put the pads on. Brand new $20 shipped.
Right Mirror for NNBS (2007-present trucks). 5000 miles on them. They are full power and heated mirrors. Work perfect not scratches like new plug and play. $75 shipped
35 inch bfgs a/t for 20 inch rims with about 5000 miles on them they look new no burnouts or anything. Prefer not to ship $1000.
ATS copilot for Duramax diesels with 5 speed automatic Allison 1000 transmissions. Updated version. Comes complete with all the wiring and regulator and control box. Works awesome increase clutch plate pressure and prevents slipping between shifts. It is a great way to beef up your Allison without spending $5000 dollars. $650 shipped.
OEM painted white flares for 99-07 trucks great condition $300 shipped
Bushwacker Cut-out Flares like new for 99-07 trucks great conditions $475 shipped
Do the mirrors have the turn signals? What color are they?
    250.3k
    Pro Street Jim
    Pro Street Jim
  • Who's Online   0 Members, 0 Anonymous, 451 Guests (See full list)
