Seat Covers?
The GM ones! :thumbs:
Get them while you can though,They are being discontinued due to the fact that the 2010's all have side-impact air bags in the seat backs,Therefore the covers can't be used anymore.
The GM ones! :lol:
:D:mad::thumbs:
Yeah, I noticed that they only list the rear GM seat covers for the '10 models, and fronts are only available for '09 and older. Does that mean they'll have new revised GM ones coming out that account for the side-impact air bags? I'm kind of hoping so.
    Brendan C
    Brendan C
  • Who's Online   6 Members, 0 Anonymous, 1,086 Guests (See full list)
