Decarbonization
Brewboy
I have a 2007 Yukon Denali AWD with 25,000miles and when I took it in for an oil change this last time the service tech advised that the engine had to have a "Decarbonization" treatment to the emissions system as its MANDATORY.
Is this true?
If so why, the engine has no issues?
sounds like he was trying to make some extra money. At 25,000 there shouldnt be much to worry about. Seafoam through a vacuum would do it though.
Yeah, he ripped you off.. if you paid for it. There's not call for that service that I've seen. :rollin:
Was this at a dealership? If so, ask the service tech to put that statement in writing. I'm guessing he will start reneging very quickly.
If he is stupid enough to put it in writing, promptly notify GM of that dealership's deceptive attempt to defraud you.
    President Roberto
    President Roberto
  • Who's Online   4 Members, 0 Anonymous, 1,042 Guests (See full list)
