Help with alarm please
96 Vortec
I have an older alarm that is malfunctioning.  It is an Ungo MS7000.  Anyways, the pin switch on the hood is missing and there is a loose wire now.  I have it taped up unitl I get the correct pin switch.
Now the problem, after I remote start my truck, about a minute later, my alarm will start going off.
I know I've got a pretty slim chance that anyone knows about a 5 year old alarm, but would anyone have any suggestions about some sites that would be of some help?
TIA
Jeff
  • 3 weeks later...
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
