Is this the GM Thunderform box?  Pics inside...
Someone is selling it but does not know which vehicle it is for.  It looks like the '98 and older GM ext. cab box to me, can anyone confirm this?
The only problem with those is that they are made from plastic.  IMO, MDF board is the way to go.  It's heavy as heck, but the bass response you get with a box made out of MDF and sealed with silicone plus screws would be 10x better than abs plastic.
If you've never heard a sub sealed in a homemade MDF box, then you probably wouldn't care, but once you do, you really won't want a plastic sub box again.  Plus, a 4x8 sheet of MDF only costs 15 bucks at Home Depot, plus screws, silicone, carpeting from PepBoys, you're talking 25 bucks max in parts.
Much cheaper and much better sounding way to go.
you could try reinforcing a plastic box with fiberglass, like people do with q-logic's custom kick panels. if people have the skill/time to make a mdf box, they probably will.but when you get lazy and just want to add some bass and be done. the premade boxes do get kind of appealing.
all right, let me know how it sounds. if i get a car. i may just slap one of those custom fit boxes like the mtx or jl into my truck, instead of spending a lot of time building a custom box.
Oh btw dude.  Name's Tim and I know Jeremy.  I live in Chico.
Have an '88 Iroc and am over at 3rdgen.org too.  Guess you were down at Trevor's house eh, I wanted to go but couldnt get the day off!
Well it's up and running.  Sounds great.  Actually has a lot of bass and I can turn it up and it doesnt distort, sounds good.  Both the guys at Circuit City (who installed it) were impressed with how much bass it put out.
:D
:D
How much was it? :music:
    • Compression test? Weird noises? Fuel trims?
    • I suspect at some point in the near future, the hardware will be free and you pay a subscription to access the vehicle - alldata style.
    • I've been eyeing an upgrade to my tonneau cover for a bit now.  Intrigued by the BAK MX4 EZ-Lift with the torsion spring and went for the upgrade.  Thoughts and musings during unpacking, install and a few days of usage.   Once my order went into Realtruck, it took about 4 days to ship.  Unfortunately, FedEx Ground destroyed the box and contents and it was unusable upon receipt.  To Realtruck's credit, one email with pictures and an RMA was sent to me to send the first one back, and another unit was shipped out.  It arrived 3 days later, unscathed.   I opened the box and it looked like every other BAK MX4.   Biggest differences are the rails and retaining clamps, and of course the spring attached to the cover itself.     NOTE - if you are upgrading from a MX4 to the EZ-Lift, you will have to replace the rails.  The EZ-Lift rails have a notch cut in them to allow the new style retaining clamps to fit properly.  The new retaining clamps also have 2 knobs/carriage bolts and there are two tracks underneath the front panel. The strap clips are mildly different (more like the Undercover Flex clamps) in that the screws go in from the underside.  Personally I prefer these over the BAK clamps that use the nutserts that are a nuisance to install.  The remainder of the parts in the box (drain tubes, rail clamps, and bumper pads) are standard issue BAK.     I did not replace my front bed seal at the time because it seemed to be in decent shape.   BAK recommends shims on the GM trucks unless you place the clamps on the flanges about 1/3 of the way in from both the front and rear of the bed.  I shimmed the front and the middle, and initially placed the clamps equidistant.  This also turned out to be a mistake, because when I set the cover in place, the new style retaining clamps wouldn't clear the front clamp.   New style clamp inserted in the track:     And the issue which occurred because the front rail clamp was too far forward:     Once I removed the shim from the front of the bed, and slid the clamp back to the front flange, everything cleared fine.     The cover set on the rails without issue and I installed the strap clamps.  After I completed my adjustments, I pulled the pin to activate the torsion spring.  Mistake #3 on my part.  PULL THE PIN AS THE VERY VERY VERY LAST STEP!  The reason is, once you pull the pin, the torsion spring is activated.  If you have to loosen the front clamps and adjust the cover, the front panel will - by virtue of the spring, refuse to lay down.  The only way to get it to lay down so you can reinstall and tighten the clamps is to fully open the panel against the back of the cab, which will then allow the front panel of the cover to lay down and be tightened.  Not a big deal unless you haven't installed the foam pads yet (typically the last step) because minus the foam pads, you will need to place something between the frame of the cover and the back window so it doesn't get scratched.  The next time I install one I will install the foam pads before I pull the pin and activate the spring.   After using it for a few days:   The spring assist is great.  You literally can open it with one hand.  My shoulders aren't getting any younger and this was part of my motivation to swap out. The second panel latches and unlatches itself as you open and close the cover.  Neat in concept, however it took me a minute to get used to closing the cover and not hearing the "latching" sound that would tell me it was locked in place. The paddle handles are a huge upgrade and I wouldn't be surprised to see them become the standard across the Realtruck line.  They effectively eliminate the concern that a thief could coat hanger the cover open and get to the contents in the bed. I'm not sure why the very front panel on my cover has a different finish from the other 3 panels.  I have a request into Realtruck to find out if mine was not manufactured properly or if it was by design.   All in all I'm pleased.  Same level of protection, looks good, keeps stuff mostly dry (they all leak around the tailgate) and easy to install.
