Tonneau Cover With Back Rack
I installed a Back Rack on my 2009 Sierra Crew and now I'm in the market for a tonneau cover (if possible). What are my options? I see from the back rack website that they now sell adapters which raises the back rack an inch or so. Does anyone out there have a tonneau cover/back rack setup and if so what are you running for cover? I'm lost and my local supplier is "unsure" how it would work and wants me to pay for any of his errors....lucky me.
Thanks
I have the same truck as you. I want to install a US Rack to my truck and ran into the same problem. I now have a Retrax Tonneau cover on my truck. They have 2 types of side rails for the tonneau. One is very wide and covers the stake pocket holes, and the other is narrow and is called a "cutout" side rail. It allow the use of the stake pocket holes with only a little modification. The front holes directly behind the truck cab are almost fully exposed on my truck, only 3/8" covered, while the rear box holes are only showing about 1/2" of the stake pocket hole. On the setup I will be using, I don't need the rear holes and I have left them covered. This is what I will be using the roof racks for:
http://www.loadmyboat.com/ I will be towing a 5th wheel trailer so the boat goes on the front of my truck. Only rack that fits into the stake pockets with the tonneau is the US Rack http://www.usrack.com/stake_pocket_rack.php
If you contact Retrax http://www.rolltopcover.com/ they might be able to suggest a rack that would fit with their tonneau.
Good Luck
  • 1 year later...
well I need the backrack and a tonneau cover I only see 3 options that work
I have the Truxedo Low Pro QT. I got the tonneau brackets direct from Back Rack and will be installing them this weekend. I gave it a quick dry fit the other night and it looks like its going to work out great. I will try to post pics.
    B07
    B07
  • Who's Online   3 Members, 0 Anonymous, 800 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
