Bilstein Install
When installing the 5100's how do you hold the shaft to keep it from spinning to tighten down the lock nut? I noticed the top of the shaft has two flat sides that would barely be big enough for a small crescent wrench and it is awfully small. Don't want to bend it or something trying to tighten down that lock nut. I had Ranchos before and they had a nut on top of the shock to hold when tightening down.
Anyone have a suggestion on how they did it?
I used a wrench that fit the two flat sides on the top of the shock tightly and tighted the nut down. It does look small, but it will work.
A 1/4 inch wrench is the size you need. You will have to use the open end. A box end wont fit.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
