Leveling Kit And Headlights
I know this leveling kit issue has been beat like a dead horse, I searched and could not find my answer. I just put a Rough Country Leveling Kit on my truck and I am wondering, do I have to lower my headlight angle?
have to? no. should you? eh. you can re aim them if you wish, i dont think you do though. see if anyone you get behind starts blocking there mirrors or if people start flashing their hi-beams at you.
I adjusted mine down after having the RC kit for about 9 months. Driving from NH to MI and back with a load of stuff in the back caused my low beams to be too high. Truckers on the road were flashing their brights at me after I passed them (one actually turned on his rearward facing light that was on the back of the cab).
There should be a white, plastic screw above the head lamp housing. I gave mine 2 turns down and felt it was enough.
I marked my head light height on my garage wall before installed my sky jacker 2" level kit and adjusted back to it when I finished. Seems to have worked?? Wanted to keep the factory height. I hate people bright lighting me, especially from behind. Common courtesy, I guess, but you don't have to adjust it.
yes I think you need to lower some if going over 1 inch on front lift. I raised my lows when I bought it as low beam was too low...I then lowered them some whem I put the Bils 5100s on...they are just a little higher than factory but no flashing...I drive a lot on dark roads (deer, racoons etc) and the factory setting was either wrong are too low for such driving......procedure in the manual...
I recently put on a Fabtech leveling kit, and now when I pull up behind small cars, the whole inside of their car is illuminated! I can see everything in there!! LOL! But I only see this when being behind cars that are lowered, the stock hieght cars dont seem to mind?
I lowered mine after my 4" lift because they were obviously too high. However, the aiming screws were at first confusing. They have directional arrows that say <L + R>. To me that meant sideways left and right. I looked for the up/down screws but there were none. Turns out L/R meant lower/raise. The left and right aim is fixed from the factory.
I got pulled over 2 days after installing my leveling kit while driving to work one Sunday morning about 4:00 am. The deputy told me "you'd be surprised by the number of drunks we catch for not dimming their lights". Not worth the trouble getting pulled over all the time.
I have also read that people have had problems with the front ends and bearings after installing the leveling kits...true?
Ball joints, but not bearings, yeah.
Can you get aftermarket Ball joints that are stronger or won't that fix the problem because of the suspension still being at the different angles?
    Patrick Fergy
    Patrick Fergy
  • Who's Online   1 Member, 0 Anonymous, 627 Guests (See full list)
