What Color Is This Truck?
I found this truck the other day and purchased it instantly as it was a great deal. I've been looking for a Black 2007+ silverrado and I've only wanted black but I just couldn't pass this deal up. It is a 2007 Silverrado with 11k fully loaded with leather, in-dash nav, backup sensors and almost every other option for only $22k.
I'm Picking up the truck this week and just don't know if I should of purchased it as I'm not sure if I really care for the color. I don't think its bad if it looks more like blue, but sometimes when I look at it, it kind of looks like a shade of aqua / teal. What color would you guys say it is.2iw2exy.png
Pretty Sure it's Blue Granite Metallic
That is correct, it is a nice color, go with it! :)
I have that color on mine and love it...it does seem to change color in certain light or when it is dirty...keep it clean and it will appear more blue.
man, thats so funny cuz i was in the same boat as u.. cept i wanted white or black instead of just black.. i found my truck for a good deal.. not as good of a deal as urs tho but it worked for my situation and its the same exact color.. i was definetely not crazy about the color at all at first but i can honestly say it has grown on me quite a bit.. to the point where i clean it and wax it and im like damn, that thing looks good.. u wont be dissapointed
... What color would you guys say it is...
Blue Granite Metallic FTW! :)
Well, since we're on a Blue Granite kick here, I have a set of 4 painted door handles that are brand new in the box, I got screwed and got the wrong color from someone, so these are up for sale, I'll take $75 shipped for the set
    Greg3160
    Greg3160
  • Who's Online   1 Member, 0 Anonymous, 528 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
