Tahoe Front Wheels Wont Engage
Catman59
My 2001 Tahoe wont engage the front wheels. The problem just started today. The light cycles when when you go to 4 hi , but no front wheel drive in either auto or 4Hi. I checked wiring etc . Any ideas ? Thanks guys.
I forgot to mention that I can hear the motor shifting on the case.
I jacked it up so all wheels are off the ground. It goes into 4 wheel drive when its off the ground , but on the ground it wont work ..... Please someone !!!!! :lol:
you have to be rolling slightly.read your book
don't throw parts at it
30mph the fronts still dont turn ... I drained the burnt fluid out of the case today. I would guess the clutch es are fried.
are you gonna fix it?
Its out ... I,m going to try
Well. I took out the case and split it. I found the clutch plates fried. I replaced the 10 steels and the 10 fibres. I replaced all of the seals and installed a case saver.I had a new chain , but the old one was far from being shot, so the old one got reused. With Autotrac fluid and new U-Joints Its all done for under $200. :lurk: A very simple case to work on ... and she works like a new one . The wife is back on the road :smash:
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
