[gmt900] Does It Sound Like My Auto Ac Needs Help?
Okay let me run this scenario by you and you tell me if this is normal..
2009 Silverado.. Auto AC..
Auto Turned On..
Air Temp set to 70
AC (snowflake) button OFF
Outside Air ON.
If I flip to recirculate to Interior Air only the AC Compressor kicks in and the air starts getting COLD as ICE yet the AC Indicator still shows OFF.
Lets say you just want the fan on but don't need the AC kicking in.. You don't want any heat added either. Just the outside air to flow in through the vents..
Auto turned OFF
Air Temp set to 60 (low as it will go)
Outside AIR On.
Okay so a big garbage truck pulls out in front of you and it stinks so you switch to recirculate to keep the outside air OUT!. the AC Compressor Kicks on and brings the air down to 60 Degrees yet the AC Button is STILL OFF!.
WTF!
And I might add the intelligence that the AC employs to regulate the inside temp SUCKS A$$!. 70 degrees feels like 80 and 75 feels like 90.
Auto Turned On..
Air Temp set to 70
Outside Air ON.
Auto turned OFF
Outside AIR On.
WTF!
If I am not mistaken I believe that the compressor is suppoose to turn on when you set it to recirculate. I have a Maxima and it would show that the AC was turn on when the heat was on and recirculating. My brother ( the mechanic of the family) explained that even though it is the heat and not the AC the compressor is suppose to turn on when recirculating. I dont remember exactly why it does that maybe someone else can elaborate.
The intelligence of the AC/Heater does suck. I think the unit tries to get to the interior temp that you picked really quick. For example, if you turn on the heater and set it to 75 but the sensor reads that the interior of the truck if 40, it will put out 90 degree heat to try and bring it up to 75 as fast as possible. Then when it hits 75 it will regulate itself. the only problem is that when you get into a cold truck in which the interior temp is 20 degrees and you put the temp for 75 it can blast 90 degree heat forever because it is trying to bring the temp up to 75. The problem arises because after 10 minutes of having the 90 degree heat blowing at your body and face while being completely bundled up you start to overheat while the inside temp of the truck might still be in the 50's or 60's. So you overheat and put the fan speed down and adjust the temp because you feel like it is already 75 in the truck when it is really only 50. Kind of like when its 20 degrees outside and you first go out and you say how cold it is. Then you start playing football and you start to heat up and layers of clothes start to come off. Then before you know it your in a t-shirt playing football and you think that it is now 55 degrees outside when in reality its only 30 outside.
I like my maxima for this reason. If you set the temp setting to 75 it might blow 78-80 until the temp reaches 75. It will only blow 90 if you set it to 90. so it doesnt bother me to set it to 90 for the first couple of minutes and then turn it down to 70 because once i get comfortable it will blow 70 degree heat, not 90.
Thanks for the response.. I just didn't think that made a lot of sense.. If the Compressor comes on in the Recirculate mode then why the need to have a separate ac button? At least make the AC button light up..
Normal operation. I agree, however, that I'd prefer that I get to decide myself. It's been idiot-proofed against those folks who turn on recirc and then complain because their windows fog up. I also agree that the A/C light should come on when the A/C is engaged.
    • I have thought an EV might have some practical value in extending the life of the ICE members of ones fleet. Now....I'm convinced of it. I've been letting my better half access Raven (Mitsubishi Mirage) for her needs while Dizzy has been in the shop. Being the fuel freak I am and given the fact Raven is capable of over 60 mpg in clean air on a warm day I was taken back by the wife's ability to take a car that had used a half a tank of gas that to that point had returned a value of 57 mpg and return in with a decimating 51 mpg for that same tank in that same day in a 15 mile round trip of short hop errands and a stop in the drive through at Micky D's.  😱   Trust me on this. It would take the remainder of that tank driven on the highway to return that tank to just 54 mpg. This is not a Mitsubishi issue. This is an ICE issue that is magnified in vehicles capable of such high fuel economy values. On a percentage basis your 1500 does the same thing. Short hopping an ICE consumes a good deal more fuel and in doing so provides zero additional useable outputs. That entire volume of fuel is wasted in diluting the cylinder walls oil films, creating crankcase moisture and acid content and the resultant wear.    Enter the SLATE. All of that is avoided and the ICE's advantage in range and made useful at reduced wear for your ICE!   Kind'a cool.
    • Back in the day people would buy cars based on performance. The charger posted does 0-60 in 3.3 seconds. And it’s fully loaded.  It has a decent warranty and will fit most anyone’s needs. Remember the original Hemi? 90 day warranty. 25K mini truck or that car? I’d go with the car. It wouldn’t fit my perimeter. If I could just talk my wife out of her Genesis. It would be perfect for her.
    • Let's pivot this back. Someone said they wanted pictures.   Even better, there's already video. Pre-prod prototypes are already on the road and they're letting the press drive them.   JerryRigEverything did a good review. I really enjoy his content and EV adventures, so I was thrilled when he had the chance to review a Slate:
    • The Charger EV was stillborn. Wrong car at the wrong price for Dodge's intended audience. Now at a good price with fire-sale discounts, and still not selling, it's still very much the wrong car. Again, Dodge's intended audience. I believe a lot of Stellantis' EV blunders were all under Tavares' regime at Stellantis...the board convinced him to move on. Neat car, just wasn't received on the level that would sustain mass production.   Dodge is headed in a better direction for its core business. I didn't think there was anything left to get excited about re: the Durango after its 15 year run, but they're just now releasing a 392 version that should price out in the low 40's. Nicely done. I'm not sure I would touch anything Stellantis makes with a 10' pole these days, but the Durango is still mostly parts designed like 3 parent companies ago so maybe it's still OK?
