New Exhuast
gregrocks89
So a couple days ago I finally went in to the muffler shop and got those dam glasspacks cut off. Sure is nice to punch the gas now without having everyones ears bleeding. I totally forget what the mufflers are but i just remember him telling me they are turbos and are similar to the flowmaster series.
But anyways i got a nice clean sound with a good rumble. I got rid of the 2.5" piping that came with truck before and switched out to 3" going into 4" tips on a 60 degree angle. I will get some pics put on when its not so dam cold out!
Yeah they were fun for awhile then i was getting pretty annoyed of them in the last few months. And since i got my headers put on and everytime i start my truck they would snap pretty loud as soon as the engine turns on. kept my horses on edge and everyone else around that wanted to be woken at 6am everyday
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 297 Guests (See full list)
