Dash Interchange
I have 2 trucks one is a 95 gmc sierra 1500 and the other is a 94 gmc sierra 1500 both 4x4 automatic with the 5.7. im using the body of the 94 but i like the dash and doors panels from the 95 better. are the dashes interchangable, i know the door panels are but wasnt sure of the dash. thanks in advance.
Use the entire 95 wiring harness engine & body and the steering column along air bag modules and your good to go.
im using the cab from the 94 since its in alot better shape, and the motor tranny transfercase out of 94 since it has less miles and sounds alot better, but i like the look of the dash,door panels, and steering wheel from the 95 but the 94 has better carpet and seats so im using that stuff, i just wasnt sure if the dash would bolt into the 94 cab without any problems.
No problems a drill cant fix.... :smash::lurk::lol:
seriously though...It should just bolt right in...the structure of the dash, etc. should be identical...88-98
thats what i was thinking just wasnt sure because of the difference in shape, but its no problem making it work, just wanted to see what i was getting into before i started tearing stuff out.
Note the emphases on SHOULD
yeah , i know how the shoulds always go, it can never be as easy as you think it is.
No problems a drill cant fix.... :(:lol::lol:
Sometimes its easier than you thought it was.....than you realize you did it wrong :lol::lol::lol::lol:
i hope so but i know how projects go, theres always 1 more thing to do make it look even better thats gonna add alot more work to it
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
