99 Yukon Front Axle Noise
Have a noise coming from the left front axle of my wife's 99 Yukon. There had been a noise when it was in 4WD that would go away when you put it back in 2WD. Now, there is a slight noise all the time. Don't know whether to think of a bearing or something related to the 4WD. It is similar to what a bad bearing sounds like. It is not the transfer case, I had that with my Tahoe and it was a noise that told you not to drive any further, it is from left front. What do you guys think?
This vehicle has 181k on it and may be all original. We've only had this one for alittle over a year and it's been a great trouble free truck until now. We are about to trade both the Tahoe and Yukon to vehicles with less miles on them but don't know whether to try to fix this first or just trade it.
Thanks again,
Bill
