Clunk Under Drivers Floor Pan
Before you ask, I did use the search feature! :thumbs:
I have a clunk that I feel under the drivers side floor pan that just started when it got really cold out.
Truck: 2003 Silverado 2500HD 4x4 6.0
There was no advanced warning before this started happening. I really only feel it when going from drive to reverse and reverse to drive. It is immediate after I start moving the truck in either direction and then I do not notice it afterwards. I believe that the torsion bar bushing is loose at the crossmember as I can move it around by hand and it makes a similar clunk. It sounds similar to the sound in the cab with the door shut but I am not applying the same amount of force by hand as I the truck does during acceleration. Should I see enough movement in the torsion bars under load to cause this to happen? In other words does the direction of the vehicle make a difference on the direction of force applied to the torsion bar? Maybe replacing the bushing in accordance with #PIT3459A: Torsion Bar Crossmember Bushing Replacement would help?
Searching the forums leads me to believe that it could also be the body mount, but I wouldn't think I could feel that on a level road (not that we have that many of them here). Occasionally when I hit a good patch of bumps, I feel/hear the knocking sound, too. #06-08-61-003D: Underbody Pop or Clunk Type Noise While Turning or Driving on Uneven Road Surfaces (Install Body Mount Insulator) addresses replacement of this bushing. But seeing (hearing?) that the sound is in the same location leads me to believe that this is not the problem..... yet.
Is it possible that the cold weather makes either problem more noticable? Perhaps the bushings shrink a lilttle in the cold and the problem is more pronounced. I do not believe this to be the slip joint problem that Chevy is known for. I had that in my Tahoe and know how that one feels.
Another observation is that I do not seem to feel it when the truck is in 4H. Hopefully this does not turn in to a transfer case problem.
Any advice would be greatly appreciated. I plan to put it on a lift possibly this weekend a poke around to see if anything jumps out as another potential culprit.
Thanks,
Duane
I had this exact problem. There is a vent under the driver seat that moves air to the rear passengers. I had a bolt that rolled into this vent and it would roll back and forth when I started forward or reversed.
Thanks for the reply, but this is a much heavier clunk than a bolt. After driving it today, I am noticing that it might be more centered under the cab and not just under the drivers seat. Also, contrary to what I stated earlier, I did notice it when in 4H. Hopefully I'll get it up on the lift this weekend and get a better idea of what it might be.
Would still appreciate any assistance and/or guidance that can be provided.
Duane
Well, I put the truck on the lift today. Poked around for a while and found that the mounting bolts for the transfer case were slightly loose. I guess it was enough to cause the clunk since after tightening the problem is no longer present. Due to the fine roads here in RI, I think I'll check them periodically to ensure they stay tight.
    • Engine failure requires radiator replacement per GM if it contains an engine oil cooler.  They do NOT want them flushed.  Radiator replacement is also required for the 6.2 recall if the engine fails.   Here is the TSB the dealer is referring to - 22-NA-074 1..2    Its a slightly older version, but the current version of it covers all model years 2000-2026.  So if enough failure debris was present, it gets an oil cooler.  If that is part of the radiator, it gets a radiator.  Also, same for oil cooler lines.  Those get replaced.     Now something like a 2.7 Turbo which uses an oil to water heat exchanger for the oil cooler, the radiator would be left alone but the oil cooler would be replaced, as well as any lines.
    • Doing the right thing, replacing both valves is the way to go. The valves with the ball leak far more often than the schrader. Never cared for them. The accumulator really should be replaced if the system has had no pressure in it and it was a keeper, but since you're looking to sell it, bet you can get by. Did you pull the orifice screen and see what was there?   Shame you can't get 134a. Hopefully the previous repairs included dye.   Some of the R4s I messed with developed leaks where the line sets connected or the front seal. Had one where the HPCO was leaking. Front seal would only leak under pressure. See any obvious oily spots?   I've got nitrogen I use to test pressure and to help dry the system prior to evacuation.   Keep up the good work
    • Next time you're on a road trip to a state where you can still buy it stock up on 12oz cans, you might look into getting certified so you can buy it where you are as well. When they switched from R12 to R134a the test for certification was easy, they basically just wanted the $25
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
