Heater Problems
chevysilvhd03
2003 2500hd 6.0 crew cab. driver side switches from cold to hot normal. but the passenger side stays cold at 40degrees. will switch to defrost, main vents and to the feet normal. problem is with the passenger side blowing cold when the control is set to max heat. the main control is only like 3 yrs old... any suggestions? i have unplugged 3 connectors on the passenger side lower portion of the unit to check if connections are loose... checked to see if any wires are cut. any known problems?
wife will not get in the truck till this gets fixed. :lol:
Eric
