fizzySoda Posted January 11, 2010 Posted January 11, 2010 I have a 2007 NBS 2500HD Duramax Truck. This morning upon cold start I had no power assist for the steering and brakes. The fluid level was fine. I spoke to the dealer and was told to have it towed in. When the tow truck arrived the driver went to pull it out of the driveway to load it on the flatbed and steering and brakes were working again. The dealer cannot find any problems with the system. Has anyone else experienced anything like this?
plowking Posted January 15, 2010 Posted January 15, 2010 If it does it again on a cold start,you may have to leave it overnite at the dealer. I had a problem with my hd,mine is 6.0 gas not diesel,my master cylinder was leaking down the firewall. Dealer had to replace the whole unit. Diesels don't make vacuum like a gasoline engine ,have to use a pump, could be part of same system.. plowking
Shaners Posted January 15, 2010 Posted January 15, 2010 Mine quit but never came back because the shaft sheared on the pump. I could see where this could be a very dangerous situation!
fizzySoda Posted January 16, 2010 Author Posted January 16, 2010 Yeah, I left it at the dealer for 3 days and they couldn't figure out the problem as it hasn't done it since. They don't think it will happen while driving but I am a little concerned.
RJG183SA Posted January 16, 2010 Posted January 16, 2010 I have a 2007 NBS 2500HD Duramax Truck. This morning upon cold start I had no power assist for the steering and brakes. The fluid level was fine. I spoke to the dealer and was told to have it towed in. When the tow truck arrived the driver went to pull it out of the driveway to load it on the flatbed and steering and brakes were working again. The dealer cannot find any problems with the system. Has anyone else experienced anything like this? If it does it again on a cold start,you may have to leave it overnite at the dealer. I had a problem with my hd,mine is 6.0 gas not diesel,my master cylinder was leaking down the firewall. Dealer had to replace the whole unit. Diesels don't make vacuum like a gasoline engine ,have to use a pump, could be part of same system.. plowking The HD models use a hydroboost system, not a vacuum booster. The power steering pump provides pressure for both power steering and brake assist. Did you check the fluid level?
fizzySoda Posted January 20, 2010 Author Posted January 20, 2010 Yes, the fluid level was fine. It has been a week and a half now and everything has been okay so far.
RJG183SA Posted January 20, 2010 Posted January 20, 2010 Yes, the fluid level was fine. It has been a week and a half now and everything has been okay so far. Good to hear. Hopefully it was just a random event.
