94 1500 Blower Motor Relay
hi,
i have a 94 k1500 5.7l z71 truck and i have replaced the blower motor because that stoped working but now it is only blowing out on HI and Med-Hi..it looks like it might be a relay or resistor but i am not sure. so if you can tell me what it might be and where i can find it in the truck i would appreciate it.
thanks
99% sure it's the resistor, anytime you loose lower speeds on a GM it's the resistor, once in a great while a switch, but I have done litteraly 100's of GM resistors when it is the lower speeds that are out. If you loose high then go for relay. On newer trucks they are a combined part. Blower resistors have alwasy been a big problem for GM, they have redisigned them over and over again. They get too hot and burn out, if you remove yours you most likely see rust/corrosion or burn marks. I think you have the old style with coils instead of a circuit board, pull the glove box out and it is kind of hinden behind a row of relays on top of the heater box.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
