New Guy - Ryanpublic
ryanpublic
Okay I'm the new guy. Sort of. I already posted some about the Bluestar 2010. That's how I found this sight.
I'm an EE at a utility specializing in SCADA. I used to be a mechanic (like 20 years ago). Actually I started as a makeready tech and built up to an ASE Certified Cooling System Specialist and Automotive Electrician before I switched gears on my career. Even before that I worked at a wrecking yard. Two in fact. The first one was fun but the second one sucked.
My first car was a 1968 Firebird 400CID. I was 17 and loved to play with it. Headers, Holley Carb, Crane Cam, Mallory DP Dist. Loved that car.
My last three trucks have been GM Trucks. The first was a 3 door, 4wd, z71 with heated leather seats and some other bells and whistles. Tranny blew up. Traded it for a 4 door Z71 4wd but bench seats and no real frills. This one is my baby. 2007 GMC Sierra 4door 4wd all the bells and whistles. The windshield wipers are event automatic!
I'm also an avid scuba diver, photographer, and boat owner and I got the debt to prove it!
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
