Installing Electric Fans
I used my BAW for the nut, left the belt on, tapped lightly with my BFH. Sent from my Samsung Galaxy S4 using Tapatalk 4
exactly !!!
for the real nasty fans that dont like that technique ,alittle aggresivness is required ,i use my snap on air chisel and on an angle on the fan nut flat ,hit it ,that fan spins off every time ,,,best $100 i ever spent was that tool
I dont know what year your truck is but if its 03 up you reference the pcm via pin 42 on the blue connector it can ground a relay as that is all it does with the stock arrangement. You have no a/c(defrost) system control though either way, just engine temp. Even 99 to 02 is the same deal but those don't have the a/c control anyway.
You need the pcm tuned though to activate the pins and set values for on and off though. Its not enabled as the truck sits.
Fan removal is simple. I don't tap or anything. I have big wrenches and I think its 1 3/8" that fits. Hold the water pump with a makita grinder disc tool and off it comes... no matter how seized up it is.
Sent from my SGH-I747M using Tapatalk
It's a 2003 Z71.
So tapping into the ECT won't work? I didn't think it would just because it's not an on and off switch it just tells the temprature. I knew I could do it the PCM way, it's just another expense I am trying to avoid, and my Hypertech won't do it I don't think. I may have to buy and in the block theromstat to finish it up. Should only be another $10-$20... I hope.
Chawkins... You have to be a Marine... I haven't heard that kind of talk since my Marine Days!!!
Ex air force spec ops aircraft tech
Ect is resistance.... won't do anything for you. My setup with OEM junk can be had for 100 or less BTW....
  • 5 years later...
Do you have to replace your radiator with a biger one in order to install a direct fit electric fan assembly? Im planing on doing this upgrade to my 03 silverado but i dont want to replace my radiator.. is not leaking so i was wondering if you actually have to replace for a bigger one  or you can just go on line a buy a dual fan assembly that will bolt right in. Is there any one thay can give me a website or a clue on where to find one ?
In general, no, unless you are running hotter and need more cooling (baja).
Also, depends on design of the fan.
https://www.summitracing.com/parts/flx-292/year/2004/make/gmc/model/sierra-1500
Is an example of a direct fit fan that would work with existing radiator using the existing mounts (two side tabs that go where the lower shroud would go and two upper holes where the upper shroud would go)
Some of the more powerful fans would require custom mounting and possibly different radiator. But it's all custom at that point and that is up to the installer and money.
  • 1 month later...
How can this be done without the pcm tuning I've heard its sometimes its too hard to do on the 2000 models and sometimes it won't work some  people online are charging me about $150.00 to try to tune it so someone please help out I got the 05 fans and the factory style harness with relays is there a place I can tap a grounded temp sensor to
    250.3k
    Old Bay
    Old Bay
  • Who's Online   4 Members, 1 Anonymous, 924 Guests (See full list)
    • I know when I was looking around last year to see if someone handled Amsoil gear oil to buy at the retail level which of course means full price. I found an independent shop that works a lot on GM/Duramax pickups and they did not bring in the 75W-85 as they just stuck to the 75W-90 for the front and rear as a standard practice for the HD trucks which makes sense anyway for the higher hp/torque diesel and pulling heavy loads in four wheel drive. I haven't changed my diff oils yet but still plan on using the 75W-85 for the front diff as I highly doubt I will be beating on the truck and figured for my use type the bit thinner oil would be to my benefit for the winter for that slightly less drag. Very different weather here all winter vs northern Washington near the coast, that's for sure.
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
