What To Get
ok, so i got some extra cash over the weekend and cant decide what to buy next for my truck! I was thinking along the lines of:
Hellwig Sway bar
E-Locker Differential
JBA shorty Headders (CA Legal)
I have the dominators 2 on order already and dont really have the time to drop it off at the mech to put in a new cam,rods,springs, and rockers. These 2 options are not available for one reason or another.
What should I buy? from where and how much would be a good price. I dont mind keeping some extra $$$ in my pocket after i purchase one of these :lol:
Get a throttle body spacer!! I hear is gives you at least 45 more hp! Don't forget your stickers. They add around 25 hp a piece. :lol:
With all that you already have, I personally would go with the headers. That's only because you said you don't have time for cams, head, etc.... You may just want to save that money and go with cams or heads when you have time to drop it off.
ok, so i have decided between a 1.5" BL or the subthump box with the Silverado letters. I really like how the box sits and sounds. Then again, i would really love how the truck would sit a bit higher with the 1.5" BL.
as for what to put in the box, i was thinking 2 10" Polk audio subs, not the cheapy db series but the MMC series. at least thats what i think they are. The MOMO series are nice but i would preffer the next ones up from those. and then eventually component up front and rear. some 6.5's should be good enough.
Its burning a hole in my pocket :D and I don't want to end up spending it on something I wont remember in a couple of days anyways
