What Wheel Is This?
CasualButJiggy
I think you are right sir!
If they are 17's the Ultra site shows only a 17x8 wheel available. They are for sale with 285/70-17's on them. So is that a safe purchase as far as back spacing and fitment are concerned? I have my torsion bars turned up 1 1/2".
If the bolt pattern of the dodge is not the same as your truck, then they won't fit. (i don't think they're the same..)
Bolt pattern is exactly the same 8x6.5. The backspace is 5 1/2" and the offset is +25mm.
Those all check out, right? With a 285 tire they are going to stick out just a little past the factory setting and should fit beautifully. Right?
    Fishboat
    Fishboat
  • Who's Online   3 Members, 0 Anonymous, 617 Guests (See full list)
    • Hey guys, sorry for the confusison about this. This wasn't my experainnce, it was copied and pasted fom the net.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
