Try This...
For those of you with still functioning heated washer fluid, please try this. I'd like to know if mine is the only one that does it or if there is something going wrong w/ it. I realize that if the heated washer system is going bad there's no way to fix it due to the supplier going tits up, but may have it checked out anyway. Try setting the cruise and start the heated washer cycle, wait a few seconds then cancel the cycle by hitting the button again before it starts shooting. My cruise control cancels instantly when I do this, but only during the day not at night. So I'm assuming it has to do with a voltage surge but I'm curious if any other trucks do it or if I have a problem that needs looking at before my warranty is up. Thanks for any input!
Not true,Parts are still available.
I haven't noticed that, but if I remember I'll give that a try this week.
I'll try it out, but quite frankly the entire thing pisses me off. It was working wonderful, then I went in to get the "resister" installed, and now it gets nowhere near as hot as it use to. What ever they did, I swear it lowered the temp. :uhoh:
I had the recall done on mine, and the fluid still gets hot.
Looks neat on a cold winter day with all the steam shooting out from the wipers.......
It still gets hot, steam comes out.. but it just doesn't seem to work as good as it did before :uhoh: Maybe it's in my head.
It still gets hot, steam comes out.. but it just doesn't seem to work as good as it did before :fume: Maybe it's in my head.
No comment.... :uhoh:
:D
Mine stopped working a couple of months ago and was fixed under warranty. It was the heater unit that was replaced.
OK...there is an updated ECM program available to fix your concern
You want TSB 09-08-68-001
Bring your truck to your dealer, you can wait for the repair. Takes about 25 minutes.
It's a fuse not a resistor.
I'll try it out, but quite frankly the entire thing pisses me off. It was working wonderful, then I went in to get the "resister" installed, and now it gets nowhere near as hot as it use to. What ever they did, I swear it lowered the temp. :fume:
Either way, I still don't think it gets as hot as it did prior :uhoh:
i agree, mine is not even close to being as hot as it was before the recall. before it would clean the windows on the first stroke..now i am lucky if they are clean 3 cycles later...
    Brendan C
    Brendan C
  • Who's Online   3 Members, 0 Anonymous, 1,218 Guests (See full list)
    • My brother has an Escalade. The warranty has expired so he told his wife to go to the Valvoline quick lube he uses some times. They told her if her car was a 2020 and newer 6.2 engine they wouldn’t touch it. Hers is a 2019, so they did the oil change.
