True Dual Exhaust?
I want to put an exhaust system on my truck with split dual tips in the rear, but I would also like it to be true dual with a crossover. Is there anyone that makes a kit with a crossover for the 09 Silvy? (I also have a CrewCab, 4WD, 5.3 Flex) I have scoured over most of the exhaust mfg. sites and didn't find anything that wasn't single in/ dual out. I also tried searching this forum and didn't find any specific answers. I apologize if this has already been discussed ad nauseum and I missed it. Thanks for the help!
You can do what hockeypro did on his setup, then you can decide if you need a x pipe or h pipe to "balance out/equalize" the cyclinder banks according to Magnaflow and Flowmaster. The kits I listed were actually for Corvettes and GTO's, I assumed they would have the same kits for GMC/Chevy trucks; but there isn't :thumbs:
there is no such kit. The reason you could see if you would look under your truck. Your exhaust flows from the motor to manifolds -> Catalytic converters to a "Y" junction (hence the name "Y pipe") then there is a flange - this flange separates the Y pipe from the "cat back" portion of the exhaust. The Y pipe is one welded piece and would have to be hacked up to eliminate the Y junction.
now to my question for you: why would you want a "true dual" exhaust??? if you are using a single in dual out muffler then the factory has essentially already included the "built in" X pipe.
Take it to an exhaust shop and see what they can do for you. They typically know what works the best from their experience. Pick out a muffler that you think sounds nice, and go from there.
I don't have an X or an H or any crossover for that matter. Mine both run directly from the manifold to the mufflers, and then out to the back.
your truck appears to also be an HD, I don't see any Duramax badgng so is it safe to assume you have the 6.0L?
if so your truck came from the factory with a "Y" pipe that does not connect and it had a dual inlet/ single outlet muffler in stock form, much easier to do this if desired.
I still don't see any benefit of going through the trouble to split the exhaust only to bring it back together again using a H or X pipe. The only thing you'll accomplish is adding more weight and having to buy another muffler.
+1
lol :lol: so you believe the H pipe and X pipes are gimmicks from the exhaust manufacturers to get a little extra coin from the masses... :thumbs:
your truck appears to also be an HD, I don't see any Duramax badgng so is it safe to assume you have the 6.0L? YES.
if so your truck came from the factory with a "Y" pipe that does not connect and it had a dual inlet/ single outlet muffler in stock form, much easier to do this if desired. DO WHAT?
I still don't see any benefit of going through the trouble to split the exhaust only to bring it back together again using a H or X pipe. IT'S BEEN SAID THAT IT CAN HELP BALANCE THE EXHAUST PRESSURES. The only thing you'll accomplish is adding more weight and having to buy another muffler. WHO NEEDS MUFFLERS?
My 05 6.0L came with true duals through 2 cats and into 1 muffler, dual inlet/dual outlet, then came together into 1 tailpipe right after the muffler. I have no idea why, but I trust their engineers. Anyway, before I put on my MBRP true duals, I did a bunch of reading on things like the x-pipe, H-pipe, and different length tips, all of which change the sound and the crossover pipes did have a purpose. I cannot find the thread anymore, but it is not as simple as just extra weight/cost. FWIW, I am still having a tough time getting used to hearing the dual exhaust. Not because it is louder(it replaced a flowmaster big block series single muffler-dual in/dual out to stock y-tailpipe), but since I am used to hearing everything come out of 1 pipe, the duals sound to me almost like a miss in the engine, I guess because the drivers side bank is all I really hear. I wonder if an x-pipe would help this also?
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
