Transmission Question
I have a 1993 Chevy 4x4 with a 4L80e and 180,000 miles. After a little slipping the tranny went out and will only go in reverse (no forward gears at all). Any ideas on what might be wrong and how hard it would be to fix. I am fairly competent on working on my own vehicles, but have never tackled an automatic tranny. Hate to spend the money at the shop if it is something I can fix or rebuild. Any information would be helpful.
Buy the ATSG repair manuals and possibly DVD and rebuild it if you'd like to do it yourself. This is something I'd love to tackle just to say I did it. I've thought about getting one out of the junk yard or something and rebuilding it with all the upgraded components so I can replace mine when it starts going to hell.
Brims is on the money with grabbing one out of the yard and building for future use. I built the C6 in my F... truck and it was a great learning experience. It is not difficult, but does require you to build a few special tools to compress packs and such. Also a great learning experience. The nice thing about having a good shop do the work is that they clean everything out/rebuild/replace and tune before they turn it over, and they do it in about two days. My 700r was $1000, which I figured was $350 in labor I spent to have it done by a pro. Besides that, I can go back and complain if I don't like how it is working....
--Mike
    • .30” of rain all month and it’s been weeks since that. “Mowed” our two properties today for the first time since July 2nd. It only took 30 minutes because all I had to do was level some weeds and saplings in a few problem areas. Everything else is dead.
    • Dealer reported a failed shifter module assembly so the whole shifter is getting replaced. Yet another premature repair… up to $12,000+ in extended warranty payout in only 5 years and 80,000 miles!
    • According to the dealer it’s an internal leak/failure of the compressor.  Again, another failure that shouldn’t happen at only 5 years and 80k miles.  For some reason the compressors must be hard to come by right now, because the truck’s been at the dealer almost a week and they just located a compressor at another dealer several states away today.  We’ll see if this fixes the issue.
    • I'm not sure if this should be a reply on this thread or a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - ACDelco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles. When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so i did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance.
    • I wasn’t commenting on your post. Certainly wasn’t arguing. I was making an observation on my long term experience with supposedly proper length of driving for proper heat cycles. Works for me. Although I have seen water or vapor come out of exhaust when vehicles weren’t run very long and shut off. It’s very humid in the morning. Then hot and humid.
