'73 Brake Question
I've got a '73 C20 that has an issue with a really soft brake pedal when it's cold. The problem seems most common when it's in the 30-40 degree range.
When driving, the pedal will travel basically to the floor with little or no braking action. The brake warning light will also come one. I can get some braking action at the bottom of the pedal travel, but it's minimal. A couple of times, I was able to pump the brake pedal a few times and get the light to reset off and the pedal return to normal, but in the last day or two, no amount of pumping will solve the issue.
Once the truck has warmed up considerably (like the first line on the temp gauge above the bottom line), the problem seems to go away. I had driven it slowly (25 mph and below for about 15-20 minutes) today before the brakes went back to normal. It literally seemed like a switch was tossed when the light reset and the brakes went back to normal.
I've replaced basically everything from the hard brake lines at all 4 wheels in the last couple of years, the latest being the front wheels in summer of 2009. There were no braking issues until I got to the cold temps in Nov./Dec. Once it got really cold (I'm in PA), the problem didn't seem as severe. The master cylinder has fluid in it and the system bleed just fine when I did the front brakes.
I can follow my way through project directions, but diagnosing the issue isn't my strong point. Any thoughts or suggestions would be welcome. Thanks!
pressure bleed the system again and if it acts up again with NO leaks ,replace the master cyl and do not forget to bench bleed the new unit (instructions are enclosed with the new cylinder).
temp making a difference makes no sense.
don't drive it untill its fixed please.
Would/could a master cyl going bad behave in on again/off again manner? I had no issues with it for a couple months, then a couple days, and then another couple of months with no issues before a day or two ago.
One more question - any chance it's related to the vac line on the booster, or does that display some sort of other symptom?
Thanks!
m/cyls can behave badly for sure ,very simple hyd system,
the vacuum booster stores vacuum that multiplies pedal effort ,thats it .
if the m/cyl is old and no leaks ,flip it and BENCH bleed the new one .then pressure bleed the rest of system.
vacuum booster can be checked by simply running up engine and waiting awhile and pull out the fitting and if it sucks air in audibly then its fine .
with no vac assist ,it takes alot to stop the veh .
also foot on pedal slightly, with no vacum in canister,start the truck ,pedal should go down slightly after start up
your welcome
  • 4 weeks later...
Just wanted to follow up and say thanks to everyone who posted. I swapped out the master cyclinder and all is well with the truck! The advice was helpful.
    • I thought I was building a HD 3500 srw, maybe I was lost.
    • No doubt, I definitely agree with you. However, considering the 6.2 and 3.0 have been catastrophically failing with very little miles, I figured I would put trouble free. I’m at 18,4xx and still not a single issue.
    • It’s never dry here but it gets hot. My 4 vehicles I keep at home drive an 18 mile loop. One 6 days a week. Two about 3 days each and one once a month. Only one goes on trips about 4 times a year 1000 to 2000 miles each time. One 26 years old gets driven once a month for 22 years. One 14 years old goes 6 days a week. The other two are recent at 2 and 4 years. All are performing normal no extra service other than that would be half of recommended or severe service in the maintenance manual. No extra water or steam out the exhaust or premature plug wear. I would consider an 18 mile loop would be enough. So apparently once a month at 18 miles for 22 years has kept the collector car running well. About 45 minutes a month.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
