Stting The Timeing
I have followed my manual to the letter (I think). I set piston at TDC on compression stroke. Lined up indent with white mark on lower distributer shaft, and set distributer back in. Truck wont start for anything! I have tried this about 9 times and had no luck. Before I attempted this, the truck was running great but throwing the P1345 code. I originally had to pull distributer to replace intake gasket.
Seem as if the manual is not correct on how to set the timing. You cant follow the diagram. Go TDC compression stroke on number one. Set rotor button so it points to number one wire on distributer cap. Engine is now in time with no codes popping up!
You have to set up base timing on that engine...I believe you have to pull a plug. If you time it without pulling the timing bypass your are uber retarded.
Full timing on your truck is about 27* at idle and 37* @2200 rpm
Base timing is about 8* BTDC...so if you set it up without the bypass unhooked you are off.
I'm not 100% sure on this year of truck if its the light brown wire that goes into the black box on the firewall on the passenger side though.
Nytemare, I have no idea what you are referring to. Like I said, pulled number 1 plug so we could find TDC on compression stroke, pulled distributer, lined up rotor button to #1 wire. plugged everything back up and it runs great with no service engine codes.
That is for 95 and older TBI trucks. 96 and newer vortecs you use a scanner to set timing.
yeah, that's what I started thinking after....I knew it was for anything pre OBDII, wasn't sure if the Vortec 350's held on to the base timing routine all the way up to when they were phased out.
    • FYI, I used sq body headers on my 72 and they were a perfect fit with zero clearance issues with the rods and Z bar for the clutch  I agree with post on worn mount rubber
    • I do most of my yard work before 10. My summer walks are usually at Kroger’s. Inside and yes I’ll do light shopping. Usually by noon you don’t want to be outside from June to September. The mail box is a good walk. I’ll walk there about 3 times before the mail comes. My house has two floors if I feel I need to move I’ll do the stairs. I’ll walk down the lane to our rent house with clippers trimming branches along the driveway. There’s always something to do.
    • There is a sign at my chiropractors office that says, "Don't quit, take a break." Sound advice.    On a 65 degree day (F) I can still work pretty darn hard (I'm 72). On a 85 degree day with a good deal of humidity it takes me three days to do what in took at 65 degree in three hours. If I work to muscle exhaustion (back) it will take me days more to recover. Taking breaks to prevent that is most useful. A lift belt has been very useful in preventing both.    Minister was giving a talk the other night where he was speaking of age and he used a clock to illustrate the human lifespan and it's ability to task. 1 to 45 was the second hand, scurry about. 46 to 70 the minute hand. Slower but...71 and up the hour hand...Hummm....until that talk I felt more like the minute hand. 😭   Then he says, the most useful hand on the clock is the hour hand. Without it you can't tell time. (Hour of the watch). I felt a bit better knowing we over 70 are useful. 🥹
    • I still do oil changes on our 2 vehicles and my motorcycle. I have a robot mower for the yard but can't use it in my backyard because my wonderful dog keeps digging the guide wire up so I have to push mow it. Not much of a walker especially during the summer, just to hot. I will ride my e-bike almost daily which helps to keep my knees and hips loose and helps with my balance. That's my story an I'll stick with it. We have been in the mid to high 90's with a feel like temp of 105 to 109 for the last month with no rain. We finally got some rain which cooled it off but were still stuck with the humdity. I do pace myself and that's why it takes me 2 days to do something that used to take a couple of hours.   Peace
    • @newdude great info, thank you!   So opening the thermal bypass valve early (or all the time) would cause temperature to rise more slowly, but above 194F there would be no difference from normal operation?   It seems like the only practical ways to bring down the peak temperature would be to improve the oil-air heat exchanger in some way or increase fluid capacity?
