3 Nuns.
Three nuns were in the church the other day and the 1st nun says, "I was going through the Father's office and do you know what I found? A carton of cigarettes!"
"What did you do?" the other nuns asked.
"Well, of course I threw them in the trash."
The second nun said, "Well, I can top that. I was in Father's room putting away the laundry and I found a bunch of condoms!"
"Oh my!" gasped the other nuns.
"What did you do?" they asked.
"I poked holes in all of them!" she replied.
The third nun fainted.
