Need Help Buying My First Suit..
smoak352
I have never owned a suit. I have always gotton away with slacks and a button down shirt. However, my friends wedding is coming up, which is going to be a good one as well as two charity events this spring where I would feel out of place without a suit.
So, I know nothing about suits. There is a Jos A Bank in the mall close to my house. Should I go there? I dont want something cheap, but I am only going to wear this thing maybe 1-2 times a year, so I do not want to spend a fortune. Is it possible to get something decent for $200-$300??
Thanks.
I don't know about price anymore, but yes Jos A Bank would be a good choice.
When I retired from the navy and went into the business world I went to Brooks Brothers and explained my situation. I had never had to wear a suit and for 20 years had always been told what to wear. The salesman there explained what I had to do to keep from looking stupid.
Guess the point is that these people do this all the time. It is thier job to make you look good. It was nice not having to worry about how to dress; much rather worry about finding time to go fishing.
I would pass on the Jos A Banks and the Men's Warehouse. I have bought suits from both of them in the past and have been disappointed. Brooks Brothers has some nice suits, I would go there or a nicer department store. Don't be afraid to spend some money to buy a good suit. Even though you will not be wearing it often if you buy a good suit in either black or navy blue it will last you a life time. Look for a wool or wool blend, two button is the most versatile, make sure there is a split at the lower back of the jacket (vent). And stay away from products made in china (as always) as these are cheap mass produced replicas of another brand's suit.
Also, you should ask around about a good tailor (the store you bought it from may not be the best). I have one tailor that I work with (he was the apprentice of the guy my grand father went to). I could take him a bed sheet and he would make it look good on me.
check out http://www.astorandblack.com/ They will come right to you. Or you can use the site to get some ideas of what to look for...
Sorry you had bad luck at Men's Warehouse.
I have had nothing but great results from our Men's Warehouse here in town. I have purchased several suits, jackets and even shoes from them and would highly recommend them. They offer free adjustments (within reason) and pressing for customers.
I have a couple of suits from Jos A Banks and they are a good suit. Wait until they are on sale.
I also have a couple from JCPENNEY. The Stafford line. I actually like the fit and finish of those a little better.
I have actually shopped at multiple Men's Warehouses and have had issues at everyone of them... I usually run into some poorly dressed retired car salesman who has moved onto suits who is way too pushy...
Here is a hint, if you go to the place and the person helping you does not look like someone out of GQ (Clothing Wise) You will not leave there looking any better...
It's like going to the gym to try to lose a few pounds and hiring an overweight trainer to help you out.
I have had a JC Penney Suit and one from Men's Wearhouse and one from a more local type shop. They've all been fairly equal quality, and did the job just fine. I think $200-$300 is a little low, but maybe if you're lucky. I've always used the in-house tailor just fine, but I'm not an expert of such things. :D
My Dad went into a suit shop once and said he wanted just a cheap suit for church, because he was "just a farmer, not a businessman." The salesman said, "As I recall, the first President of the United States was a farmer." :lol:
    • Can it still be Assembled I?    Stribeck says that we need a certain amount of viscosity under conditions of load and velocity to prevent two surfaces of a know roughness from tearing each other asunder. And we have marketing trying to tell the masses that those two surfaced require less of that commodity due to more exact limits being placed on the same old clearances. We also know that there are limits to how hard something can before it becomes to brittle to be viable and to smooth to 'wet' the surface and that both of those conditions have been known and met since about the Second World War.    That viscosity value shook out at 10 centistokes at 212 F just under a hundred years ago.  Give this a look: [Anton Parr]     What is advertised is the Kinematic viscosity (mm2/s) or that which has been density adjusted but the value we are after is the dynamic viscosity (mPa.s) or true viscosity. You can see that this number is dependent on density thus base stock and temperature. You can also see that an SAE 30 doesn't reach that value in this example. However an SAE 30 that is at the upper end of the SAE 30 range; 12.5 cSt (mm2/s), might. 12.5 * .83 = 10.375 (mm2/s). If you could find an SAE 30 at the upper end these days.   Then there is the complication of viscosity modifiers or VII or VM, whatever you wish to call them. Polymers added to very thin base oils, perhaps 3 to 6 cP oils, that will meet the SAE *W30 spec at 'tested' shear rates and 100 C/212F  target temperature. So a polymer fortified base that is a fraction of the 10 cP requirement Stribeck insist upon.   This could be all well and good if those polymers didn't have two very problematic 'features'. They shear or loose viscosity both 1.) permanently and 2.) temporality. And they do both omitted in the advertised data with the distinct  purpose of deceiving the consumer of the actual operating state of the fluid. I've shown the example of Warren Oils COSTCO 10.91 cSt 5W30 formuation several times where the 100 C HTHS value is 6.9 cP!! That's the temporary shear down and with and SSI or shear stability index of 9.4 cSt. Note the intentional deception in using mixed units?    After a short while that 9.4 cSt oil has a viscosity corrected dynamic value of 7.8 cP. But as the SSI is still within the range of an SAE *W30 whose lower value is 9.3 cSt.    This allows them to continue to call this SAE 16 weight oil a 30 weight, the cake, and still meet the API requirements for fuel efficiency IMPROVEMENT mandated by the EPA. The eating of the cake. By the time you've worn out your motor doing the responsible thing by adhering to the warranty requirements, (the stick), you get deprived of the carrot, wear control. So sad, to bad.   So what can be done? Do I need actually say? [Anton Parr]       Even this must be monitored if the oil is on the low side and the VII an organic or you opt for a 0W40 with an even lighter base oil and more / higher MW VII. (Note the lower density of the 40 weight versus the SAE 30 mono-weight?)    There is another workaround. Temperature. An SAE *W30 run at a bulk temperature of between 180 and 195 F.    Being the belt and suspenders sort I am I do both. Run it cook and run it heavy.    In Part II I'll work the AW package.
    • So, do I go elbow-deep on this thing or list it for sale and play dumb? Seems to "runs good."   I'm about $1200 away from having: -a rebuilt injector ($300) -a new cat ($250) -a new cat back exhaust (OE style) ($300) -a new AC compressor ($200) -AC refrigerant charge ($150)   In theory, this should rectify the obvious detracting issues from its value and operability. Cold AC with a non-squeaking AC pulley both sounds and feels good. An exhaust that isn't cut/hacked in 17 different places and doesn't vibrate on a crossmember would make it sound and feel less janky. A working cat would help the stink, and will save the earth, but *if and only if* the fuel system is working properly, which would also address the intermittent "rich" CEL.   Heard a good one... CEL for "Rich condition" means you haven't spent enough money on the truck lately, and it's letting you know.   Rebuilding the injector would seem to be the most important part. Replacing the cat would be secondary. I don't think mine is plugged or overly restricted, but it might be a little restricted? I have no good way to tell other than seat of the pants feel. I hate the smell.   The current theory is I have a rich idle problem: A bad fuel pressure regulator, or a leaking injector(s) being the highest probabilities. I already replaced the FPR but that doesn't mean its replacement isn't also bad. It was a new part from Dorman, but the packaging looked like it had been sitting on a shelf for 20 years.   This is the (single) upstream O2 sensor shown at idle. I'm getting a lot of "rich" it seems. Sometimes it stays high like that and doesn't drop down. That makes me think it's processing injector leaks or a partially stuck open injector.     Other times it looks like this. Nice oscillations between rich and lean, which is what I think it should be. Under load and at speed, the oscillations are nice and tight and uniform looking, high and low.     Fuel trims suggest the PCM is compensating pretty hard at idle to pull fuel out. But it's not enough to trip a CEL. Something about slowing to a stop: brake vaccum booster, EGR, or the EVAP purge is delayed, or there's pooled fuel in the intake again that's draining into a cylinder is enough to set the CEL. Of course, in two days of driving, it hasn't set. I was hoping to actually look at the freeze-frame data when it sets. IAT is high because it's idling on an 83 degree day here.
