2007 Chevy Silverado Ls Wont Switch Gears
Hey guys. I was on my way home from work and notice that my RPM's would hit at 3 and stay there when I am at 60 mph and it feels like I'm in neutral and reving (sp) the engine. When I would lay off the gas the RPMs would drop but when I step on it again, they would jump right back up. I'm not sure what the problem could be as I am a first time Chevy Silverado owner.
The truck only has 25,750 miles on it. Any help would be very much appreciated.
Since your under the 3 yrs 36K take it to the dealer.
Sounds like your trans went into limp mode....do you have a light or message on your cluster??
It doesn't show anything, which I thought was wierd.
LOL...you didn't hit your tow haul mode by mistake did you??? It feels a little weird when your not use to driving with it.
I checked that too but it's not on. I'm about to go and fire it up and take it for a ride to see if anything happened lol. Bad gas wouldn't do this would it?
Doubt it
The tow haul mode shuts off when you shut off the engine.
Doubt it
Yeah, it's still not working right. :dunno:
Doubt it
Sounds like there's a trip to the dealership in your future.
Doubt it
Yup I have scheduled for a appointment. I'll let you guys know the outcome.
  • 5 weeks later...
Wow it's been a month since I replied to this lol. Just wanted to give you guys a heads up it was a blown transmission. Sprag shot metal throughout and they put a brand new one in. Two good things. 1. Brand new tranny and 2. Didn't cost a dime.
They aren't sure what caused it, but its fixed and rides perfect.
Wierd: I would agree. With all the sensors and computers in vehicles these days, you'd think that the computer would know that something was wrong with the transmission on such a failure and at least throw a code. I mean, they have engine speed sensors, vehicle speed sensors, couldn't the computer figure out there was something wrong? :(
It should have picked something up...but if it wasn't slipping or overheating and shifting "properly" There was nothing wrong...as far as the sensors in there are concerned.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
