09 Silverado Cabin Filter?
Is there any way of adding a cabin filter or something to keep all the crap out on a 09 silverado? I work at a pallet factory/sawmill and everyday I come out and turn the air on sawdust blows out of my vents and coats my ebony interior. this is driving me nuts!
Just lay a piece of cheese cloth over the intake duct when you get out to go into work, than remove it before you jump in your truck to go home.
Is there any way of adding a cabin filter...
I've been curious about adding a retrofit cabin air filter in my '03 Silv as well (which was not equipped with one). I researched and found these, though I have no personal experience with them yet.
Whatever their reasons, GM redesigned the units to block off the filter slots. We did get lucky, though. GM left the filter boss and mounts intact. This opened up the door for a possible future retrofit
That's good news if true.
http://www.dieselplace.com/forum/showthrea...it+cabin+filter
http://cgi.ebay.com/ebaymotors/2003-2010-G...t-/230449659615
http://www.chevyavalanchefanclub.com/cafcn...;prev_next=next
http://www.gmfullsize.com/forum/showthread.php?t=145137
I did the cabin filter mod on my '04 last oct. We'll see how it does with the pollen soon. It bugs me that on a $36k vehicle the engine gets an air filter and the occupants don't.
Im going to take some time this weekend and see what i can do, I dont want to spend anymore money than i have to. Does anyone know if this will work on a NNBS anyways?
According to the ebay page it might. Will be looking at mine tomorrow for sure now.
I did the cabin filter mod on my '04 last oct. We'll see how it does with the pollen soon...
Which retro kit did you get?
Can you share your install experiences and overall impressions?
Maybe post photos?
Thanx in advance
Did this yesterday (kit from ebay) PIA to cut slot but it works fine
No more pollen or dust :thumbs:
Did this yesterday (kit from ebay) PIA to cut slot but it works fine...
That's good news. Thanx for the post.
So are the receiving slots for the filter already in the duct?
Can you post pix?
OK, so the kit on EBAY includes NAPA/WIX 4805 cabin filters. So if I am understanding this correctly all your doing is cutting the access hole- installing the filter- and reinstalling the lid ( maybe using some sealing tape)................. OK guys, I'm gonna do a little looking into this today and see if I can come up with a CHEAP solution. I'll post pics if I figure out a mod.
so you did this on your 2008?
Yes, see sig.
The instructions with the kit are copyrighted, I will respect that.
Yes, see sig.
How long did it take you?
any luck?
    bellssn690
    bellssn690
  • Who's Online   4 Members, 1 Anonymous, 544 Guests (See full list)
