OK, I am lost with this one. How is this suppose to work?
The sending unit connect the wire to ground and you have 14v to the terminal on the gauge
How can you test the gauge?
I put 12 volts to 1 terminal and ground to the other and the gauge pegs.
It would seem i need some kind of variable resistor in-line so voltage would not be full(14v)
maybe i am not understanding something
Oh by the way this is an 87 silverado truck that i am working on 1/2 ton
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
