Dumbquestion Concerning Tires
Mckenzie
I hear people on here refer to tires as 33's and 35's, what exactly does this mean? Could someone break down what each segement of the numbers 285/75/16 mean? And could i get an example of some some 33's off road tires from this website.
http://www.tirerack.com/index.jsp
Also: What is the biggest tire i can put on my stock 2001 silverado Z71 without any rubbing
Thanks
People are referring to the actual height measurement of a tire. Different brands of tire are slightly taller/shorter, but a 285/75/16 is approximately 33" tall. This tire is close to the largest you can run on your truck without a lift or suspension modifications.
Most of the online dealers have a faq page that breaks down the codes on a tire sidewall.
285 = tire width measured in mm's
75 = % of your width is your sidewall height
16= rim diameter measured in inches
Example of tire height calc:
(((tire width*sidewall height)/mm to inch coversion)*2)+rim size=overall tire height
(((285*0.75)/25.4)*2)+16=32.83
