lift with plow
ok i have a 8 foot fisher plow i am going to lift my truck to fit bigger meats what lift would work with out interfering with the push bars under the truck that support the plow
Moving this over to the suspension for you.
But, here's my take on it:
W/O spending too much money you can bet a b/l and some heavy duty T-bars and run 285's w/o a problem
To fit 33's you'd be looking at a suspension lift which is going to set you back a few grand.
  • 4 weeks later...
Put a 3" body lift on your truck. You might also want to crank the torsion bars a few rounds. I have 3" body lift and cranked my torsion bars about an inch. I have 33x12.50 16.5 tires and with my 7.5 foot snow plow on my tires rub my mud flaps only at full lock. If you put 285/75/R16s on you wouldnt need to crank your t-bars any. One of my buddies has a half ton with a 2" body lift and 285's and they dont rub any. But they dont look as good as the 33x12.50's, cause the 285 are narrower.
