I've Officially Heard It All
95Sierra
So I'm trying to sell my trans am and I know the battery is pooched. I've charged it, boosted it, tried to let the car charge it and it will not hold a charge. It's got a 3yr free replacement warranty on it and a 9yr limited warranty on it. I've had it for just over a year so I take it back expecting it to be an easy swap. HAH!
I get a new manager that just admitted to the previous customer she has no idea what shes doing. She tries to hook her tester up to my battery with the cap still on the negative terminal.... Then when she goes and asks for help it comes up that it has to be charged to be tested as the charge is too low. I informed her that it WILL NOT hold ANY KIND of charge in order for them to do so. She persists that she has to charge it to get it to work. Apparently, she doesn't understand that it WILL NOT CHARGE. So I asked her, how long are you guys going to try and charge it till you realize that it will not hold a charge? She tells me it has to as there machine has to tell them that the battery is dead before they can warranty it and she's not sure how long it will take for it to charge.
At this point I'm getting pissed off, I've worked at said store, I know their protocol and what not but I also understand how batteries work. I live 20mins from this place so I can't leave it and come back in an hour so I ended up taking it home. Whoever buys the car will have to do the warranty process on there own, I can boost the car off of the lincoln and get it to at least start but ARGHHH just replace the ****ing thing!!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
    • Do you think this width might affect the chalk test with a higher pressure closer to 65psi? I think lowering the pressure makes sense to get the tread to lay flatter
