Can't Get Into 4-low
GMGuy84
I'm having trouble getting my 2005 Silverado into 4 Low. I have push button 4wheel drive and have no problems getting into auto or 4 high. When I push 4-Low the light just flashes and it stays in 2 wheel. Any thoughts?
yes i do ,you can try shifting while rolling very slow in neutral,if that does not work,you have a concern either electrical (diag trouble code,DTC) or mechanical,if that is the case ,the t-case HAS to come out and apart for a wee looksee.
good luck brother
good luck brother
On that same note...you are putting the trans in NEUTRAL before you try and engage 4LO right?
Sorry...I have to ask...Some people don't know.
