Edge Cts Programmer
This is the CS, not the touch screen. I made a mistake when I named this! SORRY! I have had this for about a month now and it is like new, I have everything that came with it including the box! I am selling because I am going to get a custom tune. It comes with the dash mount which is not included in the new purchase, It also has the windshield mount. I paid over $430 for this and will settle for $300 It is the 85150 and Fits certain Chevy and GM's from 2001-2009. Check this to make sure it fits your vehicle. http://www.edgeproducts.com/product.php?pk=122&pvk=345. Here is a chart of HP and Torque gains http://www.edgeproducts.com/product_images...icle-pdf-35.pdf . The pictures on the dash are the actual unit.
Is it touch screen or does it have buttons on the left side?
This has the buttons on the left side, I put the wrong name by mistake. It is the CS, not CTS. I have someone interested at this time but if you are interested, PM me and I will let you know if the other person does not buy it.
    • “It should be recognized, however, that there becomes a point where fuel economy oils do not make much economic sense for the end consumer—we talk about a fuel saving of ~€100 compared to a risk of €1000 Euros if the oil is too thin and causes increased engine wear rates. However, the benefit of these oils accrues to the car manufacturers. If their vehicles can save 1–2% fuel by using a special fuel economy lubricant, then that OEM can drastically reduce the amount of fines they need to pay.”   I liked this and the following paragraph as well but it’s really only touching the beginning of the benefits OEMs see from spec’ing these oils. After you factor in “out of warranty” service work and new car sales when these engines fail before their time, it’s a good racket for them. Just because you're paranoid doesn't mean they're not out to get you!
    • Too much voodoo and snake oil.   Time to go EV    😉
