2010 Silverado Body Lift
So I have decided to go with the BL vs SL (thank you to everyone that helped me decide) However I have called Zone and performance and they have informed me that they do not have any RD out on the 2010 Silverado's. Does anyone know what the changes are from a 2009 to a 2010 and if the 2009 BL will work on the 2010?
they "should" be identical.
try giving Performance Accessories a call to see if they verified their kits for the 2010 model year yet.
rancho told me they haven't released a 2010 kit yet either and 4wheelparts.com said that they're not even out for '09s yet but when I called 4wheelparts they said they've put 09 rancho kits on 2010 and they work fine. thatas a sharp silverado, it'll look good with that lift and some tires, black bow tie's, and clear corner headlights
  • 4 weeks later...
I just finished installing the zone 3.5 kit on a 2010 gmc sierra. the instructions for the kit were for 2007-2009 trucks. the only thing that was different was the bed lift. instructions said there were 4 bolts on each side of the bed and there's only 3. so i had 2 pucks left over. other than that, everything from the instructions was the same.
Either the regular or long bed trucks have 4 bolts on each side and use the same kit part #. So they didn't change the number of bed bolts from 2009 to 2010... its that you had the bed configuration that only has 3 bolts on each side; crew cab 1500 right?
you are correct, 1500 CC.
    FiLo
    FiLo
  • Who's Online   6 Members, 1 Anonymous, 649 Guests (See full list)
