Inside Door Handles On The Gmt900
does anyone else think they are in the worst possible location? i am a bigger guy and have to lean over to get my hand half way down the door to grab the damn handle. would it have been that hard to install the damn thing higher on the door? is there anything that can be done for this?
The base GMT900 truck handles are in roughly the same place they were in on ALL GMT800s.... so :tear:
As mentioned, the up-level/SUV interior has them located higher on the door.
Upgrade to a SLT or LTZ. Problem solved. Their door handles are sitting on high like giraffe poonanny.
Yeah that is the only thing you can do, or swap some LTZ door panels into the truck.
I am a fat ass and have no problem with the door handle. Don't remember it ever being an issue. You must take "big guy" to a whole other level. :tear:
I'm doing this to mine and have several problems. The extended cab has the seat belt recoil bolted to the floor at the back end. This requires a cut out in the door panel. I have cut the section out of my original panel and melted it into the new door panel. Another problem is the window switch on the the pickups is different and will not fit into the panel. I purchased the correct switch and the connections were wrong. So I had to cut apart the switch bevels and glue them back together. And the last big problem is that the cable that connects the handle to the latch is about 15" to short to reach the new location, you can't buy the cable alone and have to buy the hole latch assembly. Another small issue is the interior panel at the mirror locations does not match the contour of the new panels so you have buy new ones.
Hell man, I just meant upgrade his truck. :tear:
I would have traded the thing in before I got into all of this... Good Luck
I did notice the low handle when I was buying my truck.I ended up with an LTZ so I have since forgotton about it.It should be higher though,why they make 2 differant kinds in the trucks is a mystery too me as this just adds to the engineering costs
They moved the location of the door handles forward on the 2010's (non SLT/LTZ)
Any pics?
a friend of mine just bought a 2010, next time I see him I'll take some pics. There is a noticable difference on the interior door panel
Any pics?
I was test driving a 2010 with 6.2l and 6 speed automatic, but it was an LTZ and the interior looked exactly the same as my V-Max.
    appletrav
    appletrav
  • Who's Online   2 Members, 0 Anonymous, 501 Guests (See full list)
