New guy here!
I just purchased a 96 GMC K1500. Truck has 240K miles. Replacement 5.7 motor has about 30K miles. My question is regarding the 4x4 fuse. What exactly does this fuse do? Mine is blown and keeps blowing when shifting to 4-wheel. I have the manual shift and the truck actually seems to shift and engage in to 4-wheel just fine. The indicator light by the shifter doesn’t work though. Is this all the fuse is for? After searching the forum it seems the actuator is an issue but that seems more for trucks that don’t actually engage 4-wheel. I can tell mine is working, especially 4-low. Does anyone have a picture of the actuator? I can see two sets of connectors with two wires near the front axel but I am color blind so not sure what set goes to the actuator.
:cheers:
Same thing happened to me almost two years ago,new actuator fixed the prob.In fact,because I had that prob I joined GMT and was told of the fix :banghead:
    • It is possible to add your own 12v outlet to your truck.  Check out this video:   I verified via GM Upfitters that pin 31 is the same on the 1500 trucks.  The wire is GM part number 84779405.   You can get the GM 12v outlet from Amazon  https://www.amazon.com/Genuine-Accessory-Receptacle-25774623-13549530/dp/B0F1H9YRGF EWAY 12 Volt Power Adapter for GM   https://www.amazon.com/EWAY-Chevrolet-Silverado-Cigarette-Ignition/dp/B0915RRW6Q/ref=sr_1_1?   I just haven't figured out a good place to put the 12v outlet in my truck.   Some people are getting USB-C to 12V adapters  https://www.amazon.com/WYMECT-Cigarette-Lighter-Socket-Adapter/dp/B0F87WNQKB/ref=sr_1_1_sspa? Not sure if they provide the correct amperage that a device like a tire inflator would need.
    • Thanks; I looked there a few minutes, and I think I can find something. I really never looked there, as I thought it was stuff like PTO/aftermarket bodies/accessories like snow plows.
