Gas prices creeping back up
Zane
thats about the same as it is here.
Its hurting alot, because i have to use premium 93 with the vette...  :D
$1.239 regular
$1.329 Plus
$1.329 Premium
Here in Florence, SC.
It was $1.189 a month ago.
About the same here, on base at least.
Shaw AFB, Sumter, SC.
Tom, do you know anyone in Greeneville, SC?  They are usually 5-8 cents cheaper than us.
No, I don't.  Used to know someone that lived here, but was from Greenville, but she lives in Oklahoma now.
Isn't one of our members from the Greenville/Spartanburg area?
you know what really ^$%^$^$ me off.  Last wed night gas was $1.29 at the mobil i go to.  I was at 1/4 tank so i figured i would wait a day.  Less than 24 hrs later it jumped 13 cents.  WHY??? Its the same gas it didnt get any better.
Then today a local speedway has gas for $1.25.  Down the street about a mile away amoco has it for $1.49 WTF?????
Here in Western PA prices have been bouncing around between $1.25 and $1.32 all summer.  Right now it is $1.29/gallon.
Probably a freakin valve broke @ the refinery, so they decided to "make up" for 15 mins downtime on production!!!
Running around upper $1.30s to low $1.40s here in SE MI (Detroit in places in the $1.20s).
Consider yourselves lucky - Prices are between $1.45 and $1.59 for Reg. Unleaded depending on the station here in Upstate NY.  ARGH! :angry:
I know how you feel, I filled up with regular the day before yesterday at $1.51/gallon here in CT, but when you stop and think about it, gas really isn't that expensive for the amount of enjoyment you get out of it (well, for me at least  :wink: ).
Dang, all of yours is cheaper than mine.  We have to pay extra $$$ for reformulated gas that works horrible.  But, I think I payed about 1.59 or 1.69 a gallon for 93 unleaded for the GTP.
Regular is $1.35 in west central IL, Cross the river into Mo. and it's $1.25 to $1.35 depending on where you cross. I could be wrong but I think diesel is well under $1.45.
    CaptainDad
    CaptainDad
  • Who's Online   4 Members, 0 Anonymous, 511 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
