Tell Me What You Think
Disregard the wanted/sale post... I have no idea how to change that, so I will post it again
2008 GMC Sierra EC 5.3 liter V8 Z71 4x4
2 inch RC Leveling Kit
285-70-17 Kelly Safari TSRs
Looks good, now you need to undercoat the rear wheel wells. Also you don't have any rubbing with those 285's do you?
At first when I got them put on I was a little scared they might, but to my relief they don't rub at all.
