jiffy seal
I just picked up a roll of jiffy seal (peel and seal). I was wondering if the installation is similar to dynamat where I just press down and use a roller to adhere the jiffy seal.
I used the peel & seal from my local Lowes and I was told that it is almost identical to the dynomat but much cheaper. Yes it applies the same just peel & roll it down trying to make contact with all bumps & voids. Good luck :;):
Big Bert- I just checked out your website, and the peel and seal you have is silver. The one I bought is like a black rubber like material, Did I pick up the wrong thing?
thanks-jd
