Zone Combo Kit
I want to put a zone combo 3.5" kit or something similiar on a 2006 Sierra CrewCab 2WD. I wanna leave the wheels I have on it though, they are 18s off a 2007 Yukon Denali. From what I have found online they are 8.0" wide and the offset is 31+. Could I run this lift with these wheels and 275/70 tires without issues? Thanks in advance.
Yes. It's a body lift and keys right? If so there will be no real change to the suspension and the spindles will remain the same.
It's 2WD, so I would be a 2" spacer and a 1.5" BL. Would the spacer change weather it would rub or not?
no it wont.
FYI i would recommend getting the PA 2" body lift for your truck instead of the Zone 1.5"
if you do get the Zone kit, dont forget to order the rear bumper brackets... they dont come with the kit and are an additonal $50
no it wont.
Why do you like the PA kit better? Just for more overall height, or so I could go to smaller spacer? I dont want to run more than a 275/70/18, but it would probably look fine even with 4" lift in the front.
no it wont.
Yes, and Yes.
It's much easier to change the spacer down the road if you want to go higher/lower. For the effort you're putting into the body lift, might as well get 2" from the get go. Then you can put in 1, 1.5 or 2" spacer depending on which tire you want to run.
no it wont.
Yes, and Yes.
The PA kit looks to be more expensive, can you suggest a website where it is cheaper?
Also would I have to extend anything?
I could just put on the 2" PA kit and the tires should fit fine, and get the spacer later.
Are you including the price of the bumper brackets for the Zone kit? You know they're $50 on TOP of the 1.5" BL right?
Yeah the zone kit is $200-215 + shipping. The PA kits I saw online were in the $400-500 range.
That seems pretty expensive... I remember mine being around $280-$300 but that was a few years ago.
In that case, just get the 3" Zone body lift for $375 and call it a day :cool:
In that case, just get the 3" Zone body lift for $375 and call it a day :thumbs:
I guess I could do that, but what has to be extended? Whenever I get the money togeather and find some shops, Im going to get it priced. Maybe the 2" PA kit will be cheaper than I have found so far.
do you have a manual tcase or manual trans?
not much has to be extended otherwise...... your 06 has efans so no shroud issues, kit comes with bumper brackets and an extension for the gas filler tube if needed. download the instructions for your truck and give it a read through....
    Patrick Fergy
    Patrick Fergy
  • Who's Online   3 Members, 0 Anonymous, 887 Guests (See full list)
