Anyone Put A Brush Guard & Plow On A Truck?
0124
is there a way to put a brush guard on a truck and remove it before plowing or something along those lines? i dont know how and where a brush guard mounts to so this may sound stupid. it seems to mount up where a plow would go?
I'm going to say that it wouldn't work. Most brush guards mount in the tow hook channels on the frame. This is also where the plow mounts mount up. You'd have to take off the brush guard to put the plow mount on, and then remove the plow mount to put the brush guard back on. I don't think it would be worth it at all, but that's up to you.
I'm thinking you could have somebody make a custom bracket that will allow you to to a quick swap of the plow and brush guard. In other words, make a bracket and bolt it to the frame of the truck. Then mount the brush guard to that bracket using some kind of pin (similar to a hitch). Do the same for the plow. What do you guys think?
most brush guards are only attached to the front tow hooks with 3 bolts on each side.. its no big deal to remove at all..
Meyers had optional bull bar that connected right into thr under carraige harness on MDII plows, that guard was HD. I had it with my Meyer set up. But to answer your question, no you cant hook one up if you have a plow on, unless your plow manufacturer has optional bull bar for it. If they do, it is well worth the money cause they are 300% stronger then any brush gaurd and are mounted right to the plow carriage and are very functional.
    RangerRick17
    RangerRick17
  • Who's Online   5 Members, 1 Anonymous, 557 Guests (See full list)
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
