Coolant, Breakage?!
Alright so not a week after I got my fuel pump done this happens.....anyone know whats goin on or what I have to do to fix this...seemed like a odd one to me. When I saw the temp jump up with a cloud of steam I was hoping it was a hose somewhere but apparently not. Is this part cast into the manifold or what?
This is the peice I pulled off the hose
Same piece broke on my truck:
The previous owner or shop the owner brought it to just glued it back on. Unfortunately for me, the glue came off, and I had a pretty bad anti-freeze leak. I just doused the connection with a good amount of Gorilla Glue and it has held up, although I'm not sure it will work with the severity of your problem. This is part of the inlet hose that goes into the intake manifold, but I think it's just a plastic piece that can be replaced. Try looking for places that sell that plastic piece, I will have to soon anyway as well, since glue should never be a permanent solution.
EDIT: If this is the actual metal fitting underneath the plastic one, you're going to have to weld or tap a new fitting on there. My problem was just the plastic piece that secured the hose in place broke, which caused a leak. The metal fitting on mine was fine and still properly attached.
The heater hose connector rotted. It threads into the manifold. I would try making some radial relief cuts in the piece that's still in the manifold, then try to pry it out without damaging the threads. Use a magnet to retrieve any metal shavings that have fallen into the water jacket. Replace the connector with a Dorman 800401. Seal the threads with teflon tape and RectorSeal.
WOW. It looks like you were in need of some serious flushing there. Rust city is NOT what coolant should look like. That is a common part failure though. I've seen many posts here about them failing.
Well my Easy out cracked the threaded bung and all around the area....So I bought a new manifold and im attempting to replace it right now...Any tips, theres a mess of wires thats making me sick
